Good morning,
I had another question. I followed the directions from the rtems wiki for building and deploying the ticker example to the ZynqMP hardware and I was running into a bit of an issue. For some reason the board seems to freeze up and do nothing after transferring control to RTEMS. As such I wasn’t sure if there were any additional steps I needed to do to get this going. I am using a Kria Som KV260.
I also made sure to use the aarch64-rtems7-nm to check the location of the start flag to ensure I was loading and jumping to the right location:
0000000000010000 T _start
Output from my serial console:
ZynqMP> fatload mmc 1:1 0x1000 rtems.img
40110 bytes read in 22 ms (1.7 MiB/s)
ZynqMP> bootm 0x1000
## Booting kernel from Legacy Image at 00001000 ...
Image Name: RTEMS
Created: 2026-10-05 1:33:43 UTC
Image Type: AArch64 RTEMS Kernel Image (gzip compressed)
Data Size: 40046 Bytes = 39.1 KiB
Load Address: 00010000
Entry Point: 00010000
Verifying Checksum ... OK
Uncompressing Kernel Image
## Transferring control to RTEMS (at address 00010000) ...
