Thank you
Regarding the flash wear problem, wrt @ppisa notes:
I’m using the lc43x launchpad and not the hdk, no sdcard or external sdram.
The lc43x has 512KB RAM compared to the ls31 256KB. lc43x lets us swap the mappings between ram and flash (lc43x datasheet, page 120). For binaries < 512KB we can use regular openocd: set BMMCR1 → load binary to internal sram → run. I can create an MR with a linker script for tms570lc43x launchpad.
For larger binaries, are sources for the xcp + freertos bootloader method available?
