- Built the BSP manually.
- Modified the “Hello World” example.
0001-Hello-World-GSOC.txt (731 Bytes)
This much looks good. You need to also post a patch per [GSoC Hello](2.9. GSoC Getting Started — RTEMS User Manual 7.5ece2a4 (12th June 2026) documentation 2.9. GSoC Getting Started — RTEMS User Manual 7.5ece2a4 (12th June 2026) documentation)
It is critical that you understand that Google has made no announcements about GSoC 2027. We are happy to help you be come and RTEMS contributor with or without GSoC.
@gedare Do you want to set up a 2027 area?
