I have developed a simple SPI application on the BeagleBone Black using RTEMS. In my code, I attempt to access SPI0 using the open() system call with the device path defined as:
#define SPI_DEV "/dev/spi0"
The system is booted via U-Boot following the RTEMS user manual, targeting the arm/beagleboneblack BSP. However, when I run the application, I encounter the following error:
SPI open failed: No such file or directory (errno: 2)
This indicates that the device node /dev/spi0 is not present in the system.
I suspect that this issue may be caused by SPI not being enabled in the device tree (.dts/.dtb), or that the device path I am using is not correct for RTEMS. I would like clarification on the following points:
- Does SPI need to be explicitly enabled in the device tree for RTEMS on the BeagleBone Black?
- Are there any additional BSP configuration or driver initialization steps required to ensure the SPI device is registered and accessible under
/dev?
Iām just starting with the RTEMS. But i dont understand how actually RTEMS get device like using this /dev/i2c0, for beaglebone. I have tried to create application the way its in manual.
But there is no explicit way to use spi with /dev method.
I also opened /bsps/beaglebone/spi.c but i didnt see #define PATH_LEN (strlen("/dev/i2c-xx") + 1) which is bbb-i2c. c like statement in Spi.c.
