How do I add multiple shell commands.
I understand I have to have a rtems_shell_cmd_t for each command. What I can’t figure out is how to have multiple:
#define CONFIGURE_SHELL_USER_COMMANDS &Shell_USERCMD_Command
The CONFIGURE_SHELL_USER_COMMANDS takes a list of commands separated with comas. So you can just use
#define CONFIGURE_SHELL_USER_COMMANDS \
&first_command, \
&second_command, \
&third_command
Hey Dave,
You can put a comma-separated list in the #define. The CONFIGURE_SHELL_USER_COMMANDS gets pasted into the end of an argument list, so you can add as many as you’d like.
Thank you both, didn’t realize I needed commas!
Just another note: Depending on the application, it can also be usefull to dynamically register shell commands. You can use something like follows for that:
rtems_shell_cmd_t my_cmd = {
.name = "my-cmd",
.usage = "some useage",
.topic = "my-group",
.command = my_cmd_fun,
rv = rtems_shell_add_cmd_struct(&cmd);
assert(rv != NULL); /* Use better error handling! */
Can be sometimes usefull if you want to write something a bit more modular without a lot of #ifdef.
Hi, I can’t statically add the commands I need, I’m doing everything as written in the manual, but it looks like static addition requires something else. (RTEMS 7 & stm32f4 BSP)
static int shell_test_command(int argc, char **argv)
printf("GO!\n");
return 0;
rtems_shell_cmd_t custom_test_command = {
.name = "test",
.usage = "test - Test command",
.topic = "misc",
.command = shell_test_command,
.alias = false,
.next = NULL
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_ENABLE
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_POSIX_INIT
#define CONFIGURE_SHELL_USER_COMMANDS &custom_test_command,
#define CONFIGURE_SHELL_COMMANDS_INIT
#undef CONFIGURE_SHELL_COMMANDS_ALL
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_MAXIMUM_TASKS 5
#define CONFIGURE_MAXIMUM_POSIX_THREADS 5
#define CONFIGURE_MAXIMUM_POSIX_KEYS 16
#define CONFIGURE_MAXIMUM_DRIVERS 10
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 10
#define CONFIGURE_HEAP_SIZE (64 * 1024)
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
#include <rtems/shellconfig.h>
Shell output:
RTEMS Shell on /dev/console. Use 'help' to list commands.
SHLL [/] # test
test: command not found
SHLL [/] #
Nevertheless, I manage to register commands via: rtems_shell_add_cmd().
After examining the code, I see that the changes are made through the configuration macro in shellconfig.h file. Is this supposed to require a BSP rebuild? Or is it possible to statically register user commands only at the BSP build stage?
I add to Init():
rtems_shell_add_cmd_struct(&custom_test_command);
Shell output:
SHLL [/] # test
GO!
I figured it out, the problem was in the connection order of the header files. I will attach a workable code, perhaps it also does not correspond to the RTEMS philosophy, please correct me.
#include <rtems/shell.h>
printf("GO!\n");
return 0;
.name = "test",
.topic = "misc",
.alias = false,
.next = NULL
* @brief RTEMS init entry point
* @param ignored
* @return rtems_task
rtems_task Init(rtems_task_argument ignored)
rtems_status_code sc;
/** Start shell task */
sc = rtems_shell_init(
"SHLL",
4096,
100,
"/dev/console",
false,
true,
NULL
rtems_task_exit();
