I’m trying to use RTEMS Canadian Cross Building as described in
RTEMS User Manual (7.491f6c8) 15.3. Cross and Canadian Cross Building — RTEMS User Manual 7.491f6c8 (12th May 2025) documentation.
Before all, I have to tell that I’m a real newbie in RTEMS domain. I’m just starting using and configuring RTEMS tool chain. So please, forgive me if I’m not as clear as I should in my explanations.
Here is my work context :
- BUILD machine(B) : WSL/Linux (where the build is ran to create the Tool Chain)
- HOST machine (H) : Windows x64 (where the Tool Chain produced will run)
- TARGET machine (T) : ARM/RTEMS6 (where binaries produced by the host machine will be executed)
As recommended in User Manual, I launch the following command in WSL session :
…/source-builder/sb-set-builder --build=x86_64-linux-gnu --host=x86_64-w64-mingw32 --target=arm-rtems6 --prefix=$HOME/.local/rtems-6-arm-xilinx_zynq_a9 --bset-tar-file --no-install 6/rtems-arm-windows-host
Rsb release 6 is a constraint imposed by my customer. I have created the new build set 6/rtems-arm-windows-host.bset from 6/rtems-arm.bset specifically for Canadian Cross building.
Commands added in 6/rtems-arm-windows-host.bset vs 6/rtems-arm.bset are :
- %defineifnot build x86_64-linux-gnu
- %defineifnot host x86_64-w64-mingw32
- %defineifnot target arm-rtems6
- %define allow_cxc
Without these commands in the build set, Canadian Cross building (Cxc) is not done .
The previous sb-set-builder command fails with following error :
sylvainc@EX-PC008:~/src/rsb/rtems$ ../source-builder/sb-set-builder --build=x86_64-linux-gnu --host=x86_64-w64-mingw32 --target=arm-rtems6 --prefix=$HOME/.local/rtems-6-arm-xilinx_zynq_a9 --bset-tar-file --no-install 6/rtems-arm-windows-host
RTEMS Source Builder - Set Builder, 6 (0c685d82082a modified)
warning: environment PATH suspicious path: [Errno 13] Permission denied: '/mnt/c/Program Files/WindowsApps'
Build Set: 6/rtems-arm-windows-host
Build Set: tools/rtems-default-tools.bset
config: devel/dtc-1.6.1-1.cfg
package: dtc-1.6.1-x86_64-linux-gnu-1
building: dtc-1.6.1-x86_64-linux-gnu-1
sizes: dtc-1.6.1-x86_64-linux-gnu-1: 4.615MB (installed: 1.214MB)
cleaning: dtc-1.6.1-x86_64-linux-gnu-1
package: (Cxc) dtc-1.6.1-x86_64-w64-mingw32-1
building: (Cxc) dtc-1.6.1-x86_64-w64-mingw32-1
sizes: dtc-1.6.1-x86_64-w64-mingw32-1: 4.613MB (installed: 1.213MB)
cleaning: (Cxc) dtc-1.6.1-x86_64-w64-mingw32-1
reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-x86_64-w64-mingw32-1.txt
reporting: devel/dtc-1.6.1-1.cfg -> dtc-1.6.1-x86_64-w64-mingw32-1.xml
Build Set: devel/expat-internal.bset
config: devel/expat-2.5.0-1.cfg
package: expat-2.5.0-x86_64-linux-gnu-1
building: expat-2.5.0-x86_64-linux-gnu-1
sizes: expat-2.5.0-x86_64-linux-gnu-1: 8.896MB (installed: 0.000B)
cleaning: expat-2.5.0-x86_64-linux-gnu-1
package: (Cxc) expat-2.5.0-x86_64-w64-mingw32-1
building: (Cxc) expat-2.5.0-x86_64-w64-mingw32-1
sizes: expat-2.5.0-x86_64-w64-mingw32-1: 9.125MB (installed: 0.000B)
cleaning: (Cxc) expat-2.5.0-x86_64-w64-mingw32-1
cleaning: expat-2.5.0-x86_64-w64-mingw32-1
Build Set: Time 0:00:23.942061
Build Set: devel/gmp-internal.bset
config: devel/gmp-6.3.0.cfg
package: gmp-6.3.0-x86_64-linux-gnu-1
building: gmp-6.3.0-x86_64-linux-gnu-1
sizes: gmp-6.3.0-x86_64-linux-gnu-1: 35.536MB (installed: 0.000B)
cleaning: gmp-6.3.0-x86_64-linux-gnu-1
package: (Cxc) gmp-6.3.0-x86_64-w64-mingw32-1
building: (Cxc) gmp-6.3.0-x86_64-w64-mingw32-1
sizes: gmp-6.3.0-x86_64-w64-mingw32-1: 31.505MB (installed: 0.000B)
cleaning: (Cxc) gmp-6.3.0-x86_64-w64-mingw32-1
cleaning: gmp-6.3.0-x86_64-w64-mingw32-1
Build Set: Time 0:01:32.215594
Build Set: devel/mpfr-internal.bset
config: devel/mpfr-4.2.1.cfg
package: mpfr-4.2.1-x86_64-linux-gnu-1
building: mpfr-4.2.1-x86_64-linux-gnu-1
error: building %{name}
Build FAILED
See error report: rsb-report-mpfr-4.2.1-x86_64-linux-gnu-1.txt
Note: In some cases the error appears only in
the complete build log (see --log option)
Build Set: Time 0:00:06.828520
Build Set: Time 0:02:18.207793
Build Set: Time 0:02:18.210143
Build FAILED
The following error is notified in rsb-log-20251105-112107.txt :
checking for recent GMP... yes
checking usable gmp.h at link time... yes
checking for GMP_NUMB_BITS and sizeof(mp_limb_t) consistency... yes
checking for long to fit in mp_limb_t... yes
checking for intmax_t to fit in mp_limb_t... yes
checking if we can link with GMP... no
configure: error: libgmp not found or uses a different ABI (including static vs shared).
Please read the INSTALL file -- see "In case of problem".
shell cmd failed: /bin/sh -ex /home/sylvainc/src/rsb/rtems/build/mpfr-4.2.1-x86_64-linux-gnu-1-cxc/do-build
The following error is notified in rsb-report-mpfr-4.2.1-x86_64-linux-gnu-1.txt :
checking for TLS support using C11... yes
checking if compiler knows _Decimal64... yes
checking decimal float format... BID
checking bit-field ordering for _Decimal128... little endian
checking if _Float128 with hex constants is supported... yes
checking for Static Assertion support... yes
checking whether gcc __attribute__ ((mode (XX))) works... yes
checking for gmp.h... yes
The error appears during build of mpfr-4.2.1 package.
Build of mpfr-4.2.1 package required access to lib libgmp.a which is available in temporary folder : src\rsb\rtems\build\tmp\sb-1000-internal\lib
I found on the internet and in some chat room that sometimes there might be inconsistencies between gmp package and mpfr package release 4.2.1. I saw that it was possible to make this type of Canadian Cross building using 4.1.0 or 4.1.1 package. I have done this test (modifying accordingly some specific cfg and bset files) but the same error is encountered.
My questions :
- Is it possible to perfom a Canadian Cross Build in the context I’m describing ?
- How can I fix this problem ?
- Do you have any alternatives or some hints to go ahead in my investigations ?
Thanks in advance for any help about this problem.
