Let’s say you have built rtems under $(PREFIX)/out/7. So inside $(PREFIX)/out/7/$(ARCH)/$(BSP)/lib you should be able to find the following files:
librtemsbsp.a
librtemscpu.a
librtemscxx.a
librtemsdefaultconfig.a
librtemstest.a
in my case:
❯ pwd
$(PREFIX)/out/7
❯ fd --glob 'libr*' .
./arm-rtems7/xilinx_zynq_a9_qemu/lib/librtemsbsp.a
./arm-rtems7/xilinx_zynq_a9_qemu/lib/librtemscpu.a
./arm-rtems7/xilinx_zynq_a9_qemu/lib/librtemscxx.a
./arm-rtems7/xilinx_zynq_a9_qemu/lib/librtemsdefaultconfig.a
./arm-rtems7/xilinx_zynq_a9_qemu/lib/librtemstest.a
Lets say you have your application which just initializes rtems shell inside:
$(PREFIX)/app/hello
so building it would generate
$(PREFIX)/app/hello/build/$(ARCH)-$(BSP)/hello.exe
# in my case
$(PREFIX)/app/hello/build/arm-rtems7-xilinx_zynq_a9_qemu/hello.exe
After building tools, bsp, application and then running it with rtems-run I see what you woud expect:
RTEMS Testing - Run, 7 ()
Command Line: ./out/7/bin/rtems-run --rtems-bsp=xilinx_zynq_a9_qemu ./app/hello/build/arm-rtems7-xilinx_zynq_a9_qemu/hello.exe
Host: Linux thorfinn 6.12.59 #1-NixOS SMP PREEMPT_DYNAMIC Mon Nov 24 09:36:08 UTC 2025 x86_64
Python: 3.13.9 (main, Oct 14 2025, 13:52:31) [GCC 14.3.0]
Host: Linux-6.12.59-x86_64-with-glibc2.40 (Linux thorfinn 6.12.59 #1-NixOS SMP PREEMPT_DYNAMIC Mon Nov 24 09:36:08 UTC 2025 x86_64 )
Hello World
RTEMS Shell on /dev/foobar. Use 'help' to list commands.
SHLL [/] # help ls
ls - ls [dir] # list files in the directory
now lets say I modify rtems/cpukit/libmisc/shell/main_ls.c
rtems_shell_cmd_t rtems_shell_LS_Command = {
.name = "ls",
- .usage = "ls [dir] # list files in the directory",
+ .usage = "ls [dir] # TEST list files in the directory",
.topic = "files",
.command = rtems_shell_main_ls,
.alias = NULL,
I rebuild and install rtems libraries and I can immediately see the changes inside librtemscpu.a
❯ strings librtemscpu.a | rg 'list files'
ls [dir] # TEST list files in the directory```
But even after rebuilding my shell application I don’t see the changes getting reflected
❯ strings hello.exe | rg 'list files'
The only way I could find in order to reflect these changes are to either delete hello.exe or just modify any of the application source files.
I am guessing this happens because the build system for applications considers rtems libraries static, so it doesn’t check whether they’ve been modified or not.
