Hello,
My name is Saksham Balsane.
I followed the RTEMS Quick Start guide and successfully built RTEMS 7
with the SPARC ERC32 BSP.
I modified the hello world example located at:
testsuites/samples/hello/init.c
to print:
“Hello from The Dark Side!”
I rebuilt RTEMS and ran the test on the ERC32 simulator.
Screenshot of the output is attached below.
Patch:
From 47313095111ee52901eb0f67f2819632fb9283e5 Mon Sep 17 00:00:00 2001
Date: Fri, 13 Mar 2026 16:48:32 +0530
Subject: [PATCH] testsuites/hello: modify hello world output message
testsuites/samples/hello/init.c | 2 ±
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 76b939818a…76a9f85514 100644
— a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -41,7 +41,7 @@ static rtems_task Init( rtems_task_argument ignored )
rtems_print_printer_fprintf_putc( &rtems_test_printer );
TEST_BEGIN();
- printf( “Hello World\n” );
- printf(“Hello from The Dark Side!\n”);
TEST_END();
rtems_test_exit( 0 );
2.53.0
