Controller Area Network (CAN) Stack Improvement: BeagleBone Black D-CAN Driver Implementation [GSoC 2026]
Thank you for the guidance!
I just finished RTEMS Boot on BeagleBone Black.
During the process of bringing up RTEMS on the BeagleBone Black (BBB), I encountered an issue where the board failed to boot and no serial output was observed. After systematic debugging, I identified the root cause and successfully booted RTEMS. The debugging process and conclusions are summarized below.
1. Serial Debug Setup
To monitor the boot process, I used a USB-to-TTL serial adapter (FTDI-based, 3.3V). The connection was made via the BBB J1 debug header:
  • GND → J1 pin 1
  • TX (adapter) → J1 pin 4 (BBB RX)
  • RX (adapter) → J1 pin 5 (BBB TX)
On macOS, the serial interface was identified and accessed using:
ls /dev/cu.*
screen /dev/cu.usbserial-XXXX 115200
This setup was verified by successfully observing Linux boot logs when no SD card was inserted.
2. Initial Problem
When inserting the SD card containing the RTEMS boot files and powering on the board, the following behavior was observed:
  • No serial output
  • No normal BBB board LED activity
  • System appeared to be stalled during early boot
This suggested that the boot process was failing before reaching U-Boot or RTEMS execution.
3. Root Cause Analysis
Initially, I attempted to boot from the SD card by pressing the S2 (BOOT) button during power-up. However, this approach corresponds to a different boot mode:
  • Pressing S2 forces pure SD card boot
  • This mode requires additional bootloader files:
    • MLO
    • u-boot.img
In my setup, the SD card only contained:
  • rtems-app.img
  • am335x-boneblack.dtb
  • uEnv.txt
These files are intended for a different boot method:
  • Using the U-Boot already stored on the onboard eMMC
  • U-Boot reads uEnv.txt from the SD card and executes the boot commands
Because the SD card did not include MLO and u-boot.img, forcing SD boot caused the board to fail very early, resulting in no serial output.
4. Correct Boot Method
The correct procedure for this setup is:
  1. Power off the BBB
  2. Insert the SD card
  3. Open the serial terminal
  4. Power on the board without pressing the S2 button
In this mode:
  • The onboard eMMC U-Boot runs first
  • U-Boot detects and loads uEnv.txt from the SD card
  • The RTEMS image is loaded using fatload and started with bootm
5. Result
After using the correct boot procedure:
  • Serial output appeared as expected
  • RTEMS booted successfully
  • The system executed the RTEMS application correctly
This confirmed that:
  • The SD card contents were correct
  • The uEnv.txt configuration was valid
  • The DTB (am335x-boneblack.dtb) was appropriate
  • The issue was purely related to incorrect boot mode selection
6. Key Takeaways
  • There are two distinct SD boot paths on BBB:
    • eMMC U-Boot + SD (uEnv.txt method) → does NOT require S2 button
    • Pure SD boot (ROM boot) → requires MLO and u-boot.img
  • Pressing the BOOT button without proper bootloader files leads to silent boot failure
  • Serial debugging via J1 is essential for diagnosing early boot issues
  • Correct understanding of the BBB boot flow is critical for RTEMS bring-up
7. Next Steps
  • Compare Linux CAN (c_can driver) behavior with RTEMS CAN stack
This debugging process significantly improved my understanding of the BBB boot sequence and RTEMS integration, and will help guide further development work.
I have completed a draft of my proposal. I would greatly appreciate any feedback or suggestions to help improve it. Here is the link of my draft proposal.
Generally OK, I can provide even some other C-CAN and D-CAN code examples. It is important to decide which header files style ti use for registers definition.
We have prepared even DCAN header for TMS570 project and RTEMS BSP long time ago which could be used as start
rtems/bsps/arm/tms570/include/bsp/ti_herc/reg_dcan.h
But I would suggest to convert register overlay structure to the offsets defines or enum. The fields can be defined even simpler way, as it is in rtems/cpukit/dev/can/ctucanfd/ctucanfd_kregs.h
As for the the implementation, I would suggest to use FIFO mode and IF3 for reception. This makes driver incompatible with C_CAN but that is extremely old and due to lack of support for reasonable reconstruction of proper frame receive order, it is really hard to use. I have done some driver in LinCAN framework for C_CAN (see), but I do not suggest to consider this attic HW. Some fragments from the code can be reusable. We have another CCS based DCAN support with DMA based on CCS HAL. But again, I would not be against the ideas reuse but no code and CCS header and support routines style.
The first phase should finish with the driver in state where one message buffer is used for Tx and FIFO for Rx. Then the second half should be focused on options how to use more Tx buffers but keep FIFO Tx order for given priority class and then how to allow higher priority classes to overtake Tx of messages from lower priority ones. The infrastructure for this in the old LinCAN and now RTEMS CAN FD stack is significant advantage to similar stack in lot of other OSes. But doing this properly on D-CAN HW would require some investment and inventions. The use of DMA can be additional optional golden point if time allows it.
But main goal is sound and priority classes aware RTEMS D-CAN driver. There should be reserved some time for its real time propertise checking, similar way as is done analyzis in @michallenc thesis and as we do not with SJA1000 where original design seems to be capable, OpenCores SJA1000 seems to have blockers for realiable priority overtakes.
As for development, I suggest to deliver RTEMS by U-boot and TFTP to the board. If you have some local network which provides IP addresses by DHCP server and you can specify or can be sure that your computer has fixed one assigned, then you can run TFTP server on your host computer and configure U-boot on the board to load image or even better control file/script from your computer. Then the whole physical iteration wit the board is pressing of the reset button and it loads your latest RTEMS build which you copy always during build to the directly served by TFTP daemon.
For case where I am not at home, I have network configuration which I call island net which sets my computer address as static, starts DNSMASQ as DHCP and DNS server and I have there configuration to control start of my HW. I provide even public net access to the devices by NATiing over WiFi for example. But at home, I use central DHCP server which I have there. But it is usually part of WIFi routers, DSL modem etc…
Thank you so much for your insights and guidance! Really valuable!! I updated my draft of proposal. Please help take a look and comment any suggestion.Thanks!!
I will continue development based on your suggestion.
The first stage will establish a minimal working driver with initialization, basic transmit functionality, and FIFO-based reception. The second stage will extend the driver to support interrupt-driven operation, improved mailbox usage, and priority-aware transmission scheduling, allowing higher-priority messages to preempt lower-priority ones.
The implementation will follow RTEMS conventions, using offset-based register definitions and ensuring compatibility with existing CAN stack interfaces, also consider optional DMA support.
Just a remainder the proposal needs to be submitted by March 31 18:00 UTC. I think you should also update RTEMS Gitlab tracking page with the link to the proposal.
Thanks for reminding! I will apply soon and add the link of proposal to the RTEMS Gitlab tracking page.
Yes make sure that you do, anyone without a tracking page is at risk of being rejected for non-compliance with our expectations.
Thank you! I have added the proposal link to the RTEMS GitLab tracking page. I am very interested in this project and was wondering if you have any suggestions on what I could do to improve my chances of being selected. Thanks for your guidance!
RTEMS BBB TFTP Boot Workflow (Simplified Main Flow)
more specific version and details can be seen in my Blog week1.
Goal
Establish a fast RTEMS development workflow:
Mac→ TFTP Server→ Ethernet→ BBB U-Boot→ RAM boot→ RTEMS
without repeatedly reflashing SD cards.
1. UART Serial Console
Connect the BBB using a USB-to-TTL adapter:
TX RX GND
Find the serial device on macOS:
ls /dev/cu.*
Connect using:
screen /dev/cu.usbserial-XXXXX 115200
This is used for:
  • accessing U-Boot
  • viewing RTEMS boot logs
2. Enter U-Boot
Press the space bar during BBB boot to interrupt autoboot and enter:
the U-Boot shell.
3. Configure Ethernet
Mac IP:
192.168.5.1
BBB U-Boot configuration:
setenv ethact ethernet@4a100000setenv ipaddr 192.168.5.4setenv serverip 192.168.5.1
Verify connectivity:
ping 192.168.5.1
This confirms BBB ↔ Mac Ethernet communication.
4. Start the TFTP Server on macOS
macOS exports TFTP files from:
/private/tftpboot
Create a working directory:
mkdir ~/tftpboot
Create symbolic links:
sudo ln -sf ~/tftpboot/rtems-app.img \  /private/tftpboot/rtems-app.img
sudo ln -sf ~/tftpboot/am335x-boneblack.dtb \  /private/tftpboot/am335x-boneblack.dtb
Start the TFTP server:
sudo launchctl load -F \/System/Library/LaunchDaemons/tftp.plist
5. Build the RTEMS Application
Generate:
hello.exe
Convert it into a bootable U-Boot image:
arm-rtems7-objcopy hello_dcan.exe \  -O binary app.bing
zip -9 app.bin
mkimage \  -A arm \  -O linux \  -T kernel \  -a 0x80000000 \  -e 0x80000000 \  -n RTEMS \  -d app.bin.gz \  rtems-app.img
6. Update the TFTP File
Copy the updated image:
cp rtems-app.img ~/tftpboot/
No need to recreate the symbolic links.
7. Download RTEMS via TFTP on BBB
In U-Boot:
tftpboot 0x80800000 rtems-app.img
tftpboot 0x88000000 am335x-boneblack.dtb
Memory layout:
Address Content
0x80800000 RTEMS image
0x88000000 DTB
8. Boot RTEMS
Run:
bootm 0x80800000 - 0x88000000
Boot flow:
U-Boot→ RAM→ RTEMS
RTEMS successfully boots from RAM over Ethernet.
Final Fast Development Loop
Modify code    ↓./waf    ↓Generate hello_dcan.exe    ↓mkimage → rtems-app.img    ↓Copy to ~/tftpboot    ↓BBB tftpboot    ↓bootm    ↓Test RTEMS
Main Advantage
This workflow enables very fast iteration for:
  • RTEMS CAN driver development
  • BBB BSP work
  • RX/TX testing
  • interrupt debugging
  • embedded bring-up
without constantly removing and reflashing SD cards.
Linux SocketCAN Hardware Validation for AM335x DCAN1 (BeagleBone Black Linux → UTM Linux via CANable)
Objective
Before continuing RTEMS D-CAN driver bring-up, validate that the external CAN hardware path is functioning correctly.
The goal is to determine whether communication issues originate from hardware or from the RTEMS software stack.
Test Environment
Transmitter
  • BeagleBone Black
  • Debian Linux
  • AM335x DCAN1 controller
  • External CAN transceiver
Receiver
  • UTM Virtual Machine
  • Debian Linux
  • CANable USB-to-CAN adapter
  • Linux SocketCAN tools
Hardware Setup
BeagleBone Black
DCAN1 interface:
P9.24 -> DCAN1_TX
P9.26 -> DCAN1_RX
Connected to an external CAN transceiver.
CANable USB-to-CAN Adapter
Connections:
CANH -> CANH
CANL -> CANL
GND  -> GND
Bus termination:
120Ω resistor at one end
120Ω resistor at the other end
CANable termination switch:
OFF
Validation Topology
BBB Linux
AM335x DCAN1
CAN Transceiver
CAN Bus
UTM Linux VM
Linux SocketCAN
candump
Connecting CANable to UTM Linux
Initially, the CANable device did not appear inside the Linux virtual machine.
Checking available interfaces:
ip link
No CAN interface was present.
Root Cause
The USB device was attached to macOS instead of the UTM virtual machine.
Solution
In UTM:
UTM
 └─ USB Devices
     └─ Connect
         └─ canable gs_usb
After attaching the device to the VM:
ip link
Result:
can0
The CANable adapter was successfully detected by Linux.
Configure BBB Linux
Configure pin multiplexing:
config-pin p9.24 can
config-pin p9.26 can
Enable CAN interface:
sudo ip link set can1 up type can bitrate 125000
Verify:
ip -details link show can1
Configure UTM Linux SocketCAN
Bring up the CANable interface:
sudo ip link set can0 up type can bitrate 125000
Verify:
ip -details link show can0
Monitor CAN Traffic
Start monitoring CAN frames:
candump can0
The terminal waits for incoming frames.
Transmit Test Frame
From BBB Linux:
cansend can1 123#1122334455667788
Frame contents:
ID  = 0x123
DLC = 8
11 22 33 44 55 66 77 88
Observed Result
UTM Linux successfully received:
can0 123 [8] 11 22 33 44 55 66 77 88
Validation Outcome
The successful transmission confirms:
  • AM335x DCAN1 controller is operational
  • External CAN transceiver is operational
  • CAN bus wiring is correct
  • Bus termination is correct
  • CANable adapter is operational
  • UTM USB passthrough is functioning correctly
  • Linux SocketCAN configuration is correct
  • 125 kbps communication is working
Engineering Conclusion
Because Linux successfully transmitted and received CAN frames through the same hardware path, the physical CAN network was verified to be working correctly.
This allowed subsequent debugging efforts to focus exclusively on the RTEMS software bring-up path rather than hardware issues.
The validation significantly reduced the debugging scope and ultimately helped identify a missing DCAN1 pin multiplexing configuration in the RTEMS test application.
Key Lesson
When performing embedded driver bring-up, validating the hardware path independently can save significant debugging time.
By proving that the CAN controller, transceiver, bus, CANable adapter, UTM USB passthrough, and SocketCAN tools all work correctly under Linux, remaining failures can be isolated to software configuration issues rather than hardware faults.
The first merge request, in draft now.
RTEMS Integration, Installation, and First Merge Request
I develop the driver out of tree source. The process of moving the driver from my standalone test project into the RTEMS source tree, build it as part of RTEMS, install the updated RTEMS libraries, and verify that my external BeagleBone Black test application could use the installed driver successfully, the process is here.
This is what I prepared for my first RTEMS merge request.
