in RTEMS FileSystem
int rtems_rfs_format (const char* name, const rtems_rfs_format_config* config)
i see rtems_rfs_format_config struct have config.block_size but no attribute like config.block_count
typedef struct _rtems_rfs_format_config
size_t block_size;
size_t group_blocks;
size_t group_inodes;
int inode_overhead;
size_t max_name_length;
bool initialise_inodes;
bool verbose;
} rtems_rfs_format_config;
its safe to assume it formats whole disk_device in the path specified by name
if it does than is it ideal to always format the whole disk?
