GSoC 2026: Add SATA support in libbsd
I am creating this topic for users who are interested in this project and want to share their progress.
My progress:
I’ve looked at the FreeBSD source and found:
  • sys/dev/ata/*: Contains the ATA driver to interact with ATA or SATA controllers.
  • sys/dev/ata/chipsets/*: Contains drivers for SATA and PATA chipsets.
When I run FreeBSD with QEMU and specify a SATA disk with these flags:
  -device ich9-ahci,id=ahci \
  -drive file=img.qcow2,if=none,id=disk1,format=qcow2 \
  -device ide-hd,bus=ahci.0,drive=disk1
It shows as an Intel ICH9 SATA AHCI controller. Therefore, it would be reasonable to first port the chipset that QEMU emulates, i.e., chipsets/ata-intel.c.
  • sys/cam/ata/*: Contains logic for auto-detecting and redirecting I/O requests for PATA and SATA.
  • sys/dev/ahci/*: Driver for the AHCI controller (required by SATA).
The above drivers require other components of FreeBSD, like PCI and FDT drivers (which, thankfully, RTEMS already has ported).
I do have to look more into how I am supposed to import the code into RTEMS and handle licensing-related matters.
I have a few questions for the mentors:
  • What exactly do you mean by “rules for modifications” in the description of the issue?
  • What should the minimum deliverables be at the end of the project? I am thinking of porting the code and writing some sample programs for RTEMS. I would like to know if there is anything else you expect.
Project Issue Link: Add SATA support in libbsd (#48) · Issues · RTEMS / Programs / Google Summer of Code · GitLab
Rules for modification are described in the top-level README of the libbsd repo.
You should be able to run libbsd on a target (or two) and demonstrate capabilities for debugging. See if there are any open issues to work on.
We would want to see additions to the testsuite in addition to the porting, along with documentation.
thank you I’ll check it out
I’d like to ask whether this project requires hardware support.
Thanks!
It should not require hardware support.
In the issue description it does mentioned that final testing must be done in real hardware.
I’ve drafted my proposal and submitted into tracking repo, I just have few more questions for the mentors
  1. Considering the difficulty of the project, does it make sense to only focus on one BSP (i386) for development of SATA layer. Support for other BSPs can be handled post GSoC or as a separate project in upcoming year.
  2. Can you suggest any specific texts, documentation, or existing rtems-libbsd drivers that would be particularly helpful as a reference for this port? I’ve already reviewed through rtems-libbsd and freebsd source related to SATA, and read the Rules for Modification in rtems-libbsd/CONTRIBUTING.md.
Yes, I would suggest you focus on one BSP. You might want to open a topic specifically in libBSD to ask about question 2.
Thank you, I’ll keep that in mind. And I’ve created seperate post for question 2
