GSoC 2026: Introduction and Proof of Work - Yasssine (RP2350 BSP)
Hi,
I’m Yassine, Microelectronics & Embedded System student at ISIMM.
I noticed issue #5536 still has no proposal, so here I am. I have completed the Getting Started guide built the erc32 BSP, modified the Hello World sample and ran it in the simulator. Screenshot and patch attached.
0001-hello-Add-custom-greeting-for-GSoC-2026-demonstratio.txt (777 Bytes)
I would prefer to start with the RISC-V Hazard3 core since RISC-V is
an open ISA which aligns well with the open source spirit of RTEMS,
then complete the ARM Cortex-M33 side once the RISC-V port is stable.
Looking forward to any feedback from @opticron.
Hi Yassine, you can add yourself to tracking/2026 · main · RTEMS / Programs / Google Summer of Code · GitLab and search here for topics related to your project interests or start a new topic if no current topics about it. That said, it is probably too late for you to put together a competitive GSoC proposal in this round.
Hello, do you have an RP2350 board on hand to show us that you can run something on it? Doesn’t matter what it is. Thank you.
Hi @amar, thanks for reaching out! Yes, I do have an RP2350 board and I’m ready to move forward.
That’s great, please send us a screenshot of you running something on it.
Hi @amar,
My approach uses two RP2350 boards ( RPI Pico 2 ): one configured as a Debugprobe (CMSIS-DAP) and the other as the target device. The Debugprobe is detected over USB, and I can communicate with the target using picotool and OpenOCD.
I’ve attached a screenshot of the terminal output and a photo of my physical setup.
Best regards,
Yassine
This is great, thanks.
