Hello everyone,
I’m currently having trouble using the RTEMS tracing feature on RTEMS 6.1 and I would appreciate some guidance.
- After running the sequence of shell commands
rtrace start,rtrace stop, andrtrace save data.bin, I obtained adata.bintrace file. However, I cannot find any documentation explaining how to view or interpret the contents of this file. - I attempted to “dump” the file using the
rtems-record-lttngtools, but they only generated a metadata file. There was no actual event timeline or human-readable output produced, so I’m unsure whether I’m using the tool correctly. - I also tried the
trace-convertertool to process the.binfile, but it failed with the message:
Error while running objdump ***.exe
followed by a segmentation fault.
At this point, I am not sure whether these tools are actually intended to work with the generated tracing binary file.
What I am trying to achieve next:
After dumping/processing the binary trace file, I would like to:
- Understand what the next step is supposed to be — i.e. does the binary need to be converted into another intermediate format?
- Visualize the trace data in a timeline/event viewer, similar to what Trace Compass provides for LTTng recordings
- Know if there is an official or recommended workflow to convert RTEMS trace output into a format compatible with existing visualization tools (e.g. LTTng/CTF format, JSON, etc.)
If anyone has experience with the RTEMS tracing pipeline — specifically, how to go from the raw .bin produced by rtrace save to something that can actually be viewed and analyzed — I would greatly appreciate any pointers.
Thank you in advance.
