Issue creating multiple nvdisk devices – second device fails to initialize
#include <rtems/shell.h>
#include <rtems/nvdisk.h>
#include <rtems/nvdisk-sram.h>
rtems_nvdisk_device_desc rtems_nv_heap_device_descriptor[] =
    .flags  = 0,
    .base   = 0,
    .size   = 1024 * 1024,
    .nv_ops = &rtems_nvdisk_sram_handlers
    .flags  = 0,
    .base   = 0,
const rtems_nvdisk_config rtems_nvdisk_configuration[] =
    .block_size   = 512,
    .device_count = 2,
    .devices      = rtems_nv_heap_device_descriptor,
    .flags        = 0,
    .info_level   = 1
uint32_t rtems_nvdisk_configuration_size = 1;
static int create_nvdisk(void){
  rtems_status_code         sc;
  for (uint32_t i = 0; i < rtems_nvdisk_configuration[0].device_count; ++i)
    rtems_nv_heap_device_descriptor[i].base =
      malloc (rtems_nv_heap_device_descriptor[i].size);
    printf("nvdisk created\n");
    if (!rtems_nv_heap_device_descriptor[i].base)
      printf ("error: no memory for NV disk %u\n", i);
      return 1;
    printf("NV disk %u memory allocated (%u bytes)\n",
           i, rtems_nv_heap_device_descriptor[i].size);
  for (uint32_t i = 0; i < rtems_nvdisk_configuration[0].device_count; ++i) {
    rtems_status_code sc = rtems_nvdisk_initialize(i, 0, NULL);
    if (sc != RTEMS_SUCCESSFUL) {
      printf("error: nvdisk driver not initialised for device %u: %s\n",
             i, rtems_status_text(sc));
    } else {
      printf("nvdisk %u initialized successfully\n", i);
  printf ("successful\n");
  return 0;
static rtems_task Init(
  rtems_task_argument ignored)
  (void) ignored;
  create_nvdisk();
  rtems_shell_init(
    "SHLL",
    RTEMS_MINIMUM_STACK_SIZE * 4,
    100,
    "/dev/console",
    false,
    true,
    NULL
  rtems_task_exit();
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_MAXIMUM_TASKS            10
#define CONFIGURE_MAXIMUM_DRIVERS          50
#define CONFIGURE_SHELL_COMMANDS_INIT
#define CONFIGURE_SHELL_COMMANDS_ALL
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 50
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_MAXIMUM_BLOCK_DEVICES 8
#define CONFIGURE_HEAP_SIZE                (10*1024*1024)
#define CONFIGURE_POSIX_INIT
#define CONFIGURE_MAXIMUM_POSIX_THREADS         5
#define CONFIGURE_MAXIMUM_POSIX_KEYS            16
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
#include <rtems/confdefs.h>
#include <rtems/shellconfig.h>
i am trying to create multiple nvdisk device and i am getting this error
prakhar@pop-os:~/rtems-mr/app/hello$ qemu-system-sparc   -M leon3_generic   -nographic   -kernel build/sparc-rtems7-leon3/my_shell.exe
nvdisk created
NV disk 0 memory allocated (1048576 bytes)
nvdisk created
NV disk 1 memory allocated (1048576 bytes)
nvdisk 0 initialized successfully
nvdisk:error:disk create phy failed
error: nvdisk driver not initialised for device 1: RTEMS_UNSATISFIED
successful
RTEMS Shell on /dev/console. Use 'help' to list commands.
SHLL [/] # ls -la dev
total 4080
crwxr-xr-x  1 root  root           0,         0 Jan  1 00:00 console
brwxr-xr-x  1 root  root  2147483648, 538234544 Jan  1 00:00 nvda
what am i doing wrong here or this is the limitation ?
anyone’s help would be highly appreciated
if you look at rtems_nvdisk_initialize() you can see that it is initializing the rtems_nvdisk_configuration variable in the global namespace. It will attempt to initialize all the devices itself, and it doesn’t look like the initialize is intended to be called multiple times.
Yes actually I was able to figure that out but I forgot to mention it here.
Thank you for the reply.
