Hello,
While studying the POSIX compliance layer in RTEMS and looking at Work Item #3889 (“Tests needed for CLOCK_MONOTONIC”), I noticed that clock_getres() currently returns EINVAL when called with CLOCK_MONOTONIC because case CLOCK_MONOTONIC: was missing from the switch statement in cpukit/posix/src/clockgetres.c.
Per IEEE Std 1003.1-2017 (POSIX.1-2017), clock_getres(CLOCK_MONOTONIC, &res) should populate res with the clock resolution (which in RTEMS is determined by the system clock tick). Furthermore, dedicated test assertions for CLOCK_MONOTONIC in testsuites/psxtests/psxclock were missing.
I have implemented the fix and added tests in testsuites/psxtests/psxclock/init.c covering:
clock_settime(CLOCK_MONOTONIC, &tv)rejection with-1anderrno == EINVAL.clock_getres(CLOCK_MONOTONIC, &tv)resolution query returning0and positive nanoseconds.clock_gettime(CLOCK_MONOTONIC, &tv)progression ensuring non-decreasing monotonic time across delay ticks.
Verified cleanly on the sparc/erc32 BSP under the sparc-rtems7-sis simulator.
Below is the git patch:
From cd14aca4771191f5ec6aff8a9e2f0700d8169aa4 Mon Sep 17 00:00:00 2001
Date: Tue, 8 Sep 2026 08:38:19 +0000
Subject: [PATCH] posix: Support CLOCK_MONOTONIC in clock_getres and add tests
Add support for querying CLOCK_MONOTONIC resolution in clock_getres()
matching the system clock tick resolution.
Add tests in testsuites/psxtests/psxclock to verify:
- clock_settime(CLOCK_MONOTONIC) correctly returns -1 with EINVAL
- clock_getres(CLOCK_MONOTONIC) succeeds with positive resolution
- clock_gettime(CLOCK_MONOTONIC) maintains non-decreasing progression
Updates #3889.
cpukit/posix/src/clockgetres.c | 3 +++
testsuites/psxtests/psxclock/init.c | 32 +++++++++++++++++++++++++++++
2 files changed, 35 insertions(+)
diff --git a/cpukit/posix/src/clockgetres.c b/cpukit/posix/src/clockgetres.c
index e03d0bb86f..49cd333f3d 100644
--- a/cpukit/posix/src/clockgetres.c
+++ b/cpukit/posix/src/clockgetres.c
@@ -61,6 +61,9 @@ int clock_getres( clockid_t clock_id, struct timespec *res )
case CLOCK_REALTIME:
+#ifdef CLOCK_MONOTONIC
+ case CLOCK_MONOTONIC:
+#endif
case CLOCK_PROCESS_CPUTIME_ID:
case CLOCK_THREAD_CPUTIME_ID:
if ( res ) {
diff --git a/testsuites/psxtests/psxclock/init.c b/testsuites/psxtests/psxclock/init.c
index 34f2508943..4869c1517c 100644
--- a/testsuites/psxtests/psxclock/init.c
+++ b/testsuites/psxtests/psxclock/init.c
@@ -367,6 +367,15 @@ static rtems_task Init( rtems_task_argument argument )
rtems_test_assert( sc == -1 );
rtems_test_assert( errno == EINVAL );
+ /* CLOCK_MONOTONIC cannot be set per POSIX-1.2017 */
+ puts( "Init: clock_settime - CLOCK_MONOTONIC EINVAL" );
+ tv.tv_sec = 946684800;
+ tv.tv_nsec = 0;
+ errno = 0;
+ sc = clock_settime( CLOCK_MONOTONIC, &tv );
+ rtems_test_assert( sc == -1 );
+ rtems_test_assert( errno == EINVAL );
/* exercise clock_getres */
puts( "Init: clock_getres - EINVAL (invalid clockid)" );
@@ -390,6 +399,12 @@ static rtems_task Init( rtems_task_argument argument )
rtems_test_assert( !sc );
+ puts( "Init: clock_getres - CLOCK_MONOTONIC SUCCESSFUL" );
+ sc = clock_getres( CLOCK_MONOTONIC, &tv );
+ rtems_test_assert( !sc );
+ rtems_test_assert( tv.tv_sec >= 0 );
+ rtems_test_assert( tv.tv_nsec > 0 );
/* set the time of day, and print our buffer in multiple ways */
tv.tv_sec = mktime( &tm );
@@ -567,6 +582,23 @@ static rtems_task Init( rtems_task_argument argument )
test_settime_and_sleeping();
+ /* verify CLOCK_MONOTONIC non-decreasing progression across delay */
+ struct timespec mono_start, mono_end;
+ puts( "Init: clock_gettime - CLOCK_MONOTONIC non-decreasing" );
+ sc = clock_gettime( CLOCK_MONOTONIC, &mono_start );
+ rtems_test_assert( sc == 0 );
+ wait_ticks( 2 );
+ sc = clock_gettime( CLOCK_MONOTONIC, &mono_end );
+ ( mono_end.tv_sec > mono_start.tv_sec ) ||
+ ( mono_end.tv_sec == mono_start.tv_sec && mono_end.tv_nsec >= mono_start.tv_nsec )
TEST_END();
rtems_test_exit( 0 );
2.53.0
Any feedback or suggestions on this patch would be greatly appreciated.
