I’m in the poking around and getting my bearings phase of this, and I have a couple of clarification questions:
-I’m really focused on robust testing on these, Is there a preexisting test harness or API to feed standard input and assert against standard output? Or would a custom test bench be required for automated testing?
-I’ve noticed in the forums some friction around global state variables like ‘optind’, is the RTEMS preferred way to manually reset ‘optind =1;’ and ‘optreset = 1;’ at the beginning of rtems_shell_main_[cmd] functions? Or is there a mechanism within the current infrastructure that I should be using to isolate these?
Any advice or pointers around testsuites to where I should be looking is appreciated.
I will review proposals that are linked through the tracking page on gitlab. I would rather not have every contributor asking for individual blanket reviews of their proposal here.
I think there are a few tests (capture and shell) that do something for testing interactive I/O, but I don’t know if there is any standard way. There is also a unit testing framework (“T Tests”) that could be investigated for suitability.
