RTEMS Newbie can not make Deployment git clone work - bad public ssh key
I am at the steps in Deployment building a clone directory where - I have issued
git submodule add ssh://git@gitlab.rtems.org:2222/rtems/tools/rtems-source-builder.git
I don’t seem to have a way to check to see if the path is correct but I cannot connect via ssh as I do not have ssh key that matches the public key.
I was in the user manual at 5.11 - Deployment, having completed the compilation of tools for aarch64 for raspberry Pi4.
Am I missing a step. I am assuming I need to create a clone spot to build a board package for raspberry pi 4b. This was a first step in making a host development environment.
I setup my own account ab4td0602 and setup ssh public and private keys with the expectation that I needed an account on gitlab where I could clone the /rtems/tools/ directories an files for ssh access. But that is impractical since I can not access anything in the ssh://git@gitlab.rtems.org:2222/rtems/tools/rtems-source-builder.git path
I need some help with this.
You don’t need ssh access to clone. Use the https link provided in the GitLab repo. As for the docs question you should make that a separate topic I can help with getting it cloned though.
SSH access is only required if you want to push to your own repositories or forks.
git submodule add RTEMS / Tools / RTEMS Source Builder · GitLab
That worked - I cannot confirm that that is the correct module needed - but the user manual needs to be updated to avoid access problems and ambiguity of where to acquire the correct modules.
Thanks for your response Jim
You’re welcome!
@kiwichris should that be changed to use https is there a reason it’s ssh?
I can not tell yet - I didn’t get very far after that. I was able to create the submodule add - But the subsequent command
./rtems-source-builder/source-builder/sb-set-builder \
–prefix=/opt/project --log=project.txt
–bset-tar-file --no-install
project-tools
came back - Build Failed
Deployment does not have any submodules and I do not intend adding the RSB as a submodule.
Deployment’s waf configure command lets you specify a path to the version of the RSB you are wanting to build. You can build using a released RSB, a clone of the RSB on a release branch or you can use a personal copy on a local branch with changes specific to you.
