Ticks since boot combined with wake after(1)
Is the return value of rtems_clock_get_ticks_since_boot() guaranteed to be different before and after a call to rtems_task_wake_after(1) (provided, of course that the tick counter does not wrap around)?
In RTEMS 6.1, I have a task that essentially runs:
uint32_t a = rtems_clock_get_ticks_since_boot();
rtems_task_wake_after(1);
uint32_t b = rtems_clock_get_ticks_since_boot();
and at one occasion I found that b == a after the second assignment.
I would have expected that b >= a + 1 (provided the tick count does not wrap around).
This expectation is based on two assumptions:
  1. rtems_task_wake_after(1) wakes up no earlier than after the next tick.
  2. rtems_clock_get_ticks_since_boot() returns a number that is constant between two ticks, and is increased by one at every tick.
What architecture/bsp is this?
SMP could make a difference here.
It is this one: https://rtems-qual.io.esa.int/ for Gaisler GR740 LEON4 - SMP.
Ok, thanks then this makes sense for the following reason. In an SMP architecture, the rtems_clock_get_ticks_since_boot() returns the number of ticks on the boot processor. So what you might be observing is something like the following, suppose you have CPU0 as the boot processor:
  1. Task is executing on CPU1
  2. Reads a Ticks on CPU0
  3. call rtems_task_wake_after(1) to sleep for a partial tick
  4. Wake up and read b Ticks on CPU0
Because the first interval of the rtems_task_wake_after is a partial tick (it does not start on a clock tick), the task sleeps for less than a full clock tick. Due to asynchrony between CPU0 and CPU1 you get the behavior you observe.
I don’t think we currently expose an API to view the clock ticks for the executing core. This value is stored in Per_CPU_Control.Watchdog.ticks in case you’d like to check with a debugger.
If you want to sleep for a minimum amount of time, I would suggest using clock_nanosleep. This is also documented in 8.4. Directives — RTEMS Classic API Guide 7.1023b8c (8th January 2026) documentation
That makes sense, thank you for your quick reply!
