@gedare@opticron
I am interested in the Port LittleFs project (issue #5354).
First are there any mentors assigned to the project? And I want to know if there are any documentation on how to properly port an existing software to RTEMS.
Also I need your guidance on how to approach the problem now, so i can understand the full scope. It will help me to create a proper timeline for the project in the proposal.
@gedare i am going through the documentations and references you sent.
I also sent MRs on the issues related to libfs and libblock, so I am also quite learning about the filesystems in rtems.
So, I just need a guidance should I start woking on the issue now, my first step would be to go through the LittleFs documentations and source code.
Yes, a successful proposal needs to have a solid understanding about the code being ported to know what dependencies it has, what kind of limitations might exist, how active the upstream is maintained or changes, and more.
I’ve completed my study of the RTEMS filesystem/VFS integration and documented my understanding. I’m ready to move on to analyzing littlefs and its integration points.
Great. It would be good to be able to show that you can run LittleFS on some target (e.g., baremetal or another RTOS), and to be able to describe how to debug it.
@gedare Over the past few days, I’ve been studying both littlefs architecture (block abstraction, mount/format flow, crash-consistency model) and the RTEMS VFS integration model.
Based on that, I drafted a short integration approach. My current understanding is:
Store lfs_t in mt_entry->fs_info (one instance per mount)
Implement the read/prog/erase/sync callbacks in a thin RTEMS glue layer
Keep littlefs core unchanged
Map RTEMS handlers (open_h, read_h, write_h, etc.) to the corresponding littlefs APIs
Ensure offset handling remains consistent between RTEMS and lfs_file_t
Before moving toward implementation experiments,I wanted to confirm whether this architectural direction aligns with expectations for the project.
I noticed that a merge request has been opened related to the littlefs integration project. Since I am preparing a GSoC proposal for this project, I wanted to ask whether the task is still available for GSoC work or if I should consider focusing on another project instead.
I have already been studying littlefs and the RTEMS VFS integration points while drafting my proposal, so I wanted to confirm the current status before proceeding further.
I did pushed the necessary changes described in the opened threads, I’m waiting for someone to review them. Please let me know if any other engagement you expect from my side.
Sorry I might have clicked “Add to Review” instead of “Add comment” while replying to all threads. That explains why I’m not getting any responses
