Linux SocketCAN Hardware Validation for AM335x DCAN1 (BeagleBone Black Linux → UTM Linux via CANable)
From GSoC 2026 BeagleBone Black D-CAN Driver Implementation [GSoC 2026]
Objective
Before continuing RTEMS D-CAN driver bring-up, validate that the external CAN hardware path is functioning correctly.
The goal is to determine whether communication issues originate from hardware or from the RTEMS software stack.
Test Environment
Transmitter
- BeagleBone Black
- Debian Linux
- AM335x DCAN1 controller
- External CAN transceiver
Receiver
- UTM Virtual Machine
- Debian Linux
- CANable USB-to-CAN adapter
- Linux SocketCAN tools
Hardware Setup
BeagleBone Black
DCAN1 interface:
P9.24 -> DCAN1_TX
P9.26 -> DCAN1_RX
Connected to an external CAN transceiver.
CANable USB-to-CAN Adapter
Connections:
CANH -> CANH
CANL -> CANL
GND -> GND
Bus termination:
120Ω resistor at one end
120Ω resistor at the other end
CANable termination switch:
OFF
Validation Topology
BBB Linux
AM335x DCAN1
CAN Transceiver
CAN Bus
UTM Linux VM
Linux SocketCAN
candump
Connecting CANable to UTM Linux
Initially, the CANable device did not appear inside the Linux virtual machine.
Checking available interfaces:
ip link
No CAN interface was present.
Root Cause
The USB device was attached to macOS instead of the UTM virtual machine.
Solution
In UTM:
UTM
└─ USB Devices
└─ Connect
└─ canable gs_usb
After attaching the device to the VM:
ip link
Result:
can0
The CANable adapter was successfully detected by Linux.
Configure BBB Linux
Configure pin multiplexing:
config-pin p9.24 can
config-pin p9.26 can
Enable CAN interface:
sudo ip link set can1 up type can bitrate 125000
Verify:
ip -details link show can1
Configure UTM Linux SocketCAN
Bring up the CANable interface:
sudo ip link set can0 up type can bitrate 125000
Verify:
ip -details link show can0
Monitor CAN Traffic
Start monitoring CAN frames:
candump can0
The terminal waits for incoming frames.
Transmit Test Frame
From BBB Linux:
cansend can1 123#1122334455667788
Frame contents:
ID = 0x123
DLC = 8
11 22 33 44 55 66 77 88
Observed Result
UTM Linux successfully received:
can0 123 [8] 11 22 33 44 55 66 77 88
Validation Outcome
The successful transmission confirms:
- AM335x DCAN1 controller is operational
- External CAN transceiver is operational
- CAN bus wiring is correct
- Bus termination is correct
- CANable adapter is operational
- UTM USB passthrough is functioning correctly
- Linux SocketCAN configuration is correct
- 125 kbps communication is working
Engineering Conclusion
Because Linux successfully transmitted and received CAN frames through the same hardware path, the physical CAN network was verified to be working correctly.
This allowed subsequent debugging efforts to focus exclusively on the RTEMS software bring-up path rather than hardware issues.
The validation significantly reduced the debugging scope and ultimately helped identify a missing DCAN1 pin multiplexing configuration in the RTEMS test application.
Key Lesson
When performing embedded driver bring-up, validating the hardware path independently can save significant debugging time.
By proving that the CAN controller, transceiver, bus, CANable adapter, UTM USB passthrough, and SocketCAN tools all work correctly under Linux, remaining failures can be isolated to software configuration issues rather than hardware faults.
